vetteboy
- morganville, nj
They're the same, M12 and M10.
vetteboy said:Yep, sure did. Bolted right up and all the lines connected easily.
I took a 10mm shoulder bolt and cut a little 5/8" chunk out of it to make a pushrod spacer, which I dropped down the bore of the MC before I installed it. It's close but not quite...needs to be just a tiny bit longer. I can feel in the pedal that it uses the first 20% of travel before the pushrod makes contact with the piston.
But, even so, it's noticeably better. Even with the excessive free play the pedal goes just about as far as it did with the ZJ MC in 100% 'calibrated' shape. If I ever get around to messing with the spacer again it'll get even better, but once the lines are hooked up it's kind of annoying to keep taking it off and testing. Spend the time at the start to get it right and you'll be much happier.
This is how it looks installed:
You shouldn't have to modify the hood at all - but definitely check before you slam it shut.
vetteboy said:I've never tried an E350 master. I bought one and realized it was TOTALLY wrong for my booster and promptly returned it. That, or the Corvette one, is the one to use with the older single-diaphragm booster. The Corvette booster is preferred for rear disc setups; the E350 for drum.
They changed the seal and some other stuff on the dual-diaphragm one, which is why you gotta use the newer Dodge MC with it.
edit: I'm running the ZJ proportioning valve from one that had rear discs. Seems to work OK, the front wheels lock first, and I've never really had a reason to mess with it.
