sjx40250
- Alexandria VA
I have been experiencing DW in a very odd way. First it was like the wheels were out of balance. So I balanced them without a change.
Of course this happens at around 45 to 60 MPH. The last trip on the road DWites big time. It has gotten progressively worse to the point I can't go over 40 MPH.
I did a search on here for DW and with the advice of checking movement, I did.
First let me state that the track bar is relatively new from KOR, so I know that was not a contributor. All the connections looked good as my SO rocked the wheel back and forth. Then I saw the movement.
It is between the steering box and the frame with a clicking noise with each change in the direction of the wheel. This is one of the few areas I have not had a need to take it apart.
I need to inspect further to diagnose. I am hoping the spacer is broken or the bolts are loose as opposed to the rail being fractured.
What is your experience of which it is likely to be?
I have searched on here without success in finding a description of the behavior of either.
