5-90
- Hammerspace
Big Red said:I don't know about the 2 oil filters, but I run a oil filter magnet I got at Harbor Freight, it's said to get everything 2 microns and up. I'm also planning on running some Lucas oil additive. You know the one you see at Auto Zone, Kragens, etc where you can crank the little wheel and see how much better lubrication there is on the little pullies within the little display. I just added this to my dd 98' ZJ with 94K miles and plan to do the same on my 206K 91' XJ wheeler as well. The motor still runs like a champ and I'd like to keep it that way.
Troy
Everything ferromagnetic - which means particles of iron and steel. The magnet won't catch Babbitt metal (bearings) or bits of anything else - which is why I don't use one, instead opting for a quality filter.
While I'll drain every third oil change or so over a magnet, that's still not a fully reliable indicator - and I'd like to get a "filter can cutter" someday, so I can spot-check. Just haven't yet...
5-90
