xjhighroller
- santa rosa, ca
Ok guys,
I have a 1995 Jeep Cherokee XJ that is driving me nuts. It has a nasty knock that primarily occurs when the truck is in gear and under a load that progresses with speed and turns in to a heavy vibration. when the truck rolls forward you can hear it ever so faintly, but it really stands out when you put your foot on the gas and even more so when you ride the brake a little. I am almost positive that its somewhere from the motor back because I nosed the front end up to the curb in the rain and power braked it and yes, the knock was there. It’s first started as a light knocking sound that over 2-3 weeks progressed into what is now pretty nasty sounding.
The list of things that I have done:
1. Replaced the Pinion and Carrier Bearings in the rear end by local shop
2. Replaced the wheel bearings in the rear end by local shop.
3. Had my rear Chromo shafts checked to make sure they weren’t bent.
4. Had the local Shop Check the rear end to make sure that nothing was broken in the ARB air locker.
5. Had the rear driveline rebuilt by reputable local shop.
6. Replaced the transfer case with another rebuilt transfer case.
7. Replaced the trans mount bushing. Old one was shot.
8. Took truck to Transmission shop and they said no way its the automatic transmission.
What is the problem? I have a slip yoke eliminator, the transfer case is the same as the one I replaced, the driveline is a Tom Woods w/CV that has now been rebuilt, the angles all look fine. I have the guy at my drive line shop crunching the numbers for me as far as the angles go, but said he thinks its fine, I have heavy duty transfer case drops that I made out of steel round stock, and still have the problem.
Any Brainstorming would be greatly appreciated.
Thanks,
Scott
Thanks,
Scott
