RWKHausSupply
- yorba linda, Cali
I need to add about 2" to my rear shaft, and was going to do the typ (well to me) and just cut it about mid way between the slip and the CV. The current tube OD is 2" and I was just going to get a 2" ID tube and and allow for about 5" over hang on either side of the cut and slip each end in the tube adn when its the right length, just weld both ends.
Basically just sleeve it but with about a 2" wide area in the center that is just the new 2"od pipe.
My question is if theres any forseeable reason not to use 2" sched 40 for the slip extension piece? i know its heavy and all but I cant find 2.250x.120 4130 locally so screw it, might as well just get whats needed then and not go over kill?
