MoparManiac
- Amherst, NH
When I did my lift earlier this year, I was working with a 1995 XJ, roughly 180k miles, primarily driven between Montana and Alaska - TONS of nastyness underneath, and the rust on fasteners was horrible!
My biggest problems were with the Leaf Spring Bolts up front, not even my Ingersoll Rand 1/2 drive impact gun @ 640ft-lbs in reverse and 2 weeks worth of PB Blastering the thing would work. We also tried heating the weld-nut with propane... wouldn't budge.
I got mad, and bought a 3/4" impact gun making 1350ft-lbs in reverse, heated the heck outta the nut, and, it *BARELY* backed the bolt out. Just remember that when attacking a rusty nut/bolt, keep the threads oiled and stop every few turns and run it back in a turn or two to clear the build-up of rust out of the threads. Yeah, it takes a while, but you don't bust your nut/bolt by doing that.
Remember, the harder the bolt is to remove, the more foul language you are expected to use. Don't hold back, tell that bolt how you really feel. :rof:
Eric
Just a hint, propane takes forever to get bolts/nuts hot. Mapp is better and mapp/oxy will heat things up fast.
I've done numerous lifts with mapp/oxy and it works wonders every time.
