PolishX
- Eagle Riverr Alaska
ANY XJ with a 8.25 rear wont have it
the_bandit87 said:the d44 wasn't around when ABS was an option IIRC the XJ only got ABS once chryco started changing stuff in 91 or 92.
wolfpackjeeper said:you do know this thread is well over a year and a half old right?
Partial credit. The C8.25 and D44 did not have ABS. The only XJs with ABS had the D35, but not all D35s had ABS.Jess said:ABS or not depends on the rear axle. the 8.25 and D44 did not have it. The D35's all have ABS unless someone has removed it.
Correct. Thankfully.Blaine B. said:Ok, but the D44 never had ABS?
Proof? I doubt your rear axle was really a C8.25, as nobody who made that claim on has been able to prove it.2kLimited said:my old 96 classic had ABS and the 8.25 (??)
my 2000 has it too but with D35
So maybe someone resurrected the thread after using the SEARCH function. Still going to chastise them for that?wolfpackjeeper said:you do know this thread is well over a year and a half old right?
wolfpackjeeper said:when you turn the key on but do not start the motor does and ABS light come on? Are there any electrical components on the brakes or outer axles.
look, easiest way
