XJ_Rudolph
- Pleasanton, CA
I would still recommend the wideband O2 because you are increasing engine displacement and that can upset AFRs, and you need to make sure you are not leaning out.
Also, make sure you reset your ECU!!! I forgot where I read it, but there are certain steps you have to take to reset your ECU "memory". Basically the first 100 miles you drive the car the ECU "learns" how the engine responds and what the driver drives like and calibrates the ECU accordingly. With the stroked motor, the ecu needs to relearn how much fuel it needs to squirt to keep the O2 sensors happy.
Hope this helps, and i am subscribing to this thread now.
