Markos
- Seattle, WA
All:
I came up with a set of adjustable tire deflators. Cost is about $9.30 per deflator, or about $37 for a set. A savings of around $25 over a set of staun/oasis deflators. I knew it could be done easily with the right parts. It took a lot of searching to find a suitable pressure relief valve for a good price. In fact, that was the hardest part. There isn't a huge profit margin on deflators, so the cost savings isn't remarkable. If you are only looking for a couple, this could save you some cash. There are some down sides, listed in the preliminary observations below.
Parts:
Each deflator consists of a harbor freight tire chuck with a McMaster-Carr adjustable pressure relief valve threaded onto the end.
Harbor Freight Central Pneumatic Tire Chuck with Clip
Item: 42443
Price: $1.59 (on sale, link is to closest part match)
McMaster-Carr Brass Adjustable Vacuum/Pressure Relief Valve 1/4" NPT Male, 0-20 PSI
Part Number: 48935K25
Price: $7.70
Total cost was about $40 with tax and shipping. Note the price comparison above didn't include shipping for Staun/Oasis deflators.
Preliminary Observations:
I just threw these together tonight. I still need to run some more tests on these. If you are looking for a cheap deflator or two (or four), this may be the route for you.
Also, if you want an even lower profile deflator, you can try this instead. I haven't tested them, and they are just about as expensive as the adjustable:
Non-Adjustable Pressure Relief Vents:
Pics:
Parts:
Exploded View:
Tire Chuck air passage:
Valve air passage:
Completed Set:
Parts:
Item: 42443
Price: $7.70
- So easy a caveman could do it.
- In order to get the deflators to stop at the max pressure of 20 PSI, I had to remove the locking nut so I could tighten them more. The tighter you make them, the higher the cracking pressure.
- The deflators are loud, kinda like a kazoo or deflating balloon at first. It's kind of annoying, but this could also clue you in on when they are done. The noise continually decreases as the tire airs down.
- The deflators still trickle a very small amount when they should be finished. I'm attributing this to the metal-to-metal ball bearing valve not seating 100%.
- The Harbor Freight tire chucks seat well on the valve stem, with no leaks. The lever is somewhat clunky, forcing you to position them accordingly on some wheels.
- They air down pretty quickly. There is room to drill holes at the base of the deflators if you want more volume and faster flow. You could also bore out the tire chuck hole. The extra holes should help with the noise.
- If you had the correct 7.7mm tap, you could tap the end of the valve so it could screw directly on the schrader valve. You would need to insert something to depress the valve though.
Pics:
Parts:
Exploded View:
Valve air passage:
Completed Set:
