[email protected] said:Ok new question on the prop valve. From what understand the stock prop valve is 50/50 under normal conditions and sends more to front under hard braking. Is this correct? Second question is what is the difference between the check valve and the o ring that so many say i should try removing? This i my daily driver and i dont want to do anything that jepordizes my safety on road. I have read around that if i remove the o ring the proportioning valve will deliver 50/50 to front and back and loses it's ability to differntiate pressure. Is this true or does the propotioning valve still send different pressure to front and back just at a higher pressure compared to stock? I am sorry this is going on so long but for what it's worth this thread has helped me make tremendous improvements to my braking system. thanks to all.
You are right on all accounts. Stock it is 50/50 and more to the front as pedal pressure increase under hard braking. Removing the O ring will leave it at 50/50 at all times but a failure at one end or the other will cause all loss of brakes as now the fluid can pass between the front and rear side. Better to fit a p/valve from a ZJ or just its piston and spring to get a bit more to the rear under heavy braking with the O ring still in place.
