Xhavier_5478
- Colorado Springs, CO
I am in need of some advice, my cherokee has the Crown Victoria rear disc swap on a Dana 44, and the WJ big brake swap up front. I set it all up, added ZJ spring and internals to my prop valve, bled the system, and things were great. Since this is a jeep I've been working on about 5 different projects on it at anyone time, well it sat for a few weeks while I worked on other issues, when I went to drive it the next time the brakes were dragging, so I pulled the rear wheels and both calipers had constant pressure, so I pressed them back in with a c-clamp and did the same in the front, drove fine after that. Let it sit for a week or two again this time only the fronts, so I figured they were bad calipers from the Pull and Pay so I should replace them and get new ones, did that, bled the system and they were fine, fast forward a few months my jeep sat while I was doing my drive train swap, it did it again I forced the rear piston in and it was fine.
Last night after the jeep has sat 3 weeks, I actually had to bleed off some fluid from the rear caliper to force the piston back in, and the front wouldn't retract till I let some fluid out of it also, after that all are fine.
So I have found that driving as little as 3 miles will cause the pressure to build up in the rear calipers also, and make the engine strain to overcome the braking force.
I had to remove the ZJ spring and piston from the prop valve and swap in a xj one, the brake light came on but it was able to drive home with out dragging the rear wheels.
I just finished bleeding the brakes again and they were awesome for about 5 miles, and now it is dragging the rear brakes again.
Kind of at a lose for what to try next.
Does anyone run the Crown Vic disc/WJ disc combo, and did you have to go to a different Proportioning valve all together?
