BossCherokee95
- Hampton Roads, VA
so the jeep is a 93 cherokee country that originally had a dana 30 and and a dana 35 in it with abs, well a couple months ago i swapped an xj dana 44 from the junkyard in it but i couldnt get the brake drums to stop dragging. over the weekend i swapped in disc brakes from a 8.8 everything is brand new from the axle shafts seals and bearings to the calipers but for some reason i cant get a decent pedal out of it. A 10 mph roll and it wont even lock up the tires and it barely locks up the front in lose gravel. ive bleed the back serveral times and its just coming out straight fluid it we do the traditional bleeding technique. and ive tried using my pneumatic bleeder but it leaves me with mixed results so im not sure. it seems like the whole system is not getting enough pressure. we tried to put the jeep up on jackstands in the back and hold the brake to see if it would stall it (its a manual) but with the slightest amount of throttle and the pedal to the floor it just powered right over the brakes.
if you guys could give me any ideas as to what to try, id really appreciate it
