i need info on how to Permanently disable the drivers side air bag on my 96 xj as it is now a buggy and not required in wyoming any info would be very helpful
95 and 96 this is easy - it's a mechanical airbag and no electronics are involved.
Remove the trim cap from the top of the center section of the steering wheel, now get out of the vehicle (i.e. out of the line of fire of the airbag) and use an 8mm nutdriver to unscrew the bolt under that cover till it stops turning easily. The airbag is now disarmed... if you want, you can use a 10mm ratchet to remove the 4 nuts on the back of the steering wheel, pop the center section out, and remove the airbag module / guts, then reassemble. Otherwise you can simply leave the bolt unscrewed when you want the airbag off, and screw it back in when you want it enabled.
If it's street registered and you drive it on public roads I would just use the screw but if it's a dedicated offroad-only buggy, go ahead and remove it if you want :thumbup:
i unscrewed it. am i suppose to take it all the way out? or how far out? it would not come all the way out som im not sure exactly what im suppose to do i just dont want it going off in my face
No you won't be able to put the cap/cover back on with the screw sticking out an inch. It's disarmed when the screw is backed out far enough to retract the bracket which covers 2 of the 4 nuts that secure the air bag.
Why not just remove the airbag module completely? I unplugged my driver's and passenger's airbags AND removed the airbag module from under the console. No chance of it going off that way.
I wonder if an early XJ steering wheel will bolt up to a 95/96? Honestly, they only reason I wouldn't buy a 95/96 is because the steering wheel is so ugly.
thats it, pop the cover off, unscrew til it stops backing out (it will still spin, just won't move out). To re-engage, screw it back in til its "all the way in", put the cover back on.
