oldmantompkins
- Denver
Can a bad ball joint cause death wobble?
Well, you might try changing things to change the "harmonics"--try adjusting your tire pressure up/down, might make enough of a difference.
Hi, Its my first post on . I typically hover around on MN-Jeep.com.
I am new to the forum but not new to Jeeps. Aren't you all assuming worst case scenario? I read the thread. Not one person suggested that he have is front two tires put on a wheel balancer. You may have lost a wheel weight especially if they are the ones that stick on.
If one tire is out of balance it will cause your dana 30 death wobble.
OK, time for an update. DW problem still not solved.
Some say changing the damper may be a quick fix but just masks the symptoms without resolving the cause of DW. But I'm getting to the point at which I feel like trying it anyway.
As for the track bar, I have what might seem an idiot question for heyhar and others who suggested it. The track bar is just a piece of metal rod with a slight curve in the middle to get it around the diff. Other than getting bent off-road, how and why would it need replacing? Unless it is prone to metal fatigue, surely the only way it could become a problem would be if the bushes or mountings at either end were worn/bent/misaligned? On my stock XJ, the bush at the axle end is new, and the mounting bracket at the chassis end seems absolutely fine and solid. Am I missing something? I just can't see a reason to replace the track bar, nor how it would make any difference!
Front to back, swapping them left and right could still mean the front end is seeing lot's of unbalance. Other then my tires the other issue that usually caused my DW was my tracbar but it was minor compared to my tire problem. And the reason I tell you is this was the worst death wobble I had ever seen lol. Ask Billyjp2, xbobj, and xjbaadleej how bad my wobble was lol scared the crap out of them and they weren't in my jeep.- swapped the two front tyres (left and right) over. Still get DW;
a bad steering stabilizer wont cause DW, its merely a band aid if your steering is good you dont need it.
but it doesnt hurt to replace it if it is bad.
how new is the trackbar?
i second checking the trackbar bushing and TRE.
have someone crank the wheel back and forth and watch the trackbar
is the trackbar bushign at the axle end good?
is the trackbar TRE at the frame good?
then crank on the 4 mounting bolts for the trackbar bracket. make sure that thing is tight as hell. if its even a little loose it can casue DW. i know it from experience, it happened to me one day. cranked it down, then it was gone.
are there any frame cracks around the trackbar bracket?
check ball joints for play. shake tires around (off the ground first)
check control arm bushings. check all upper and lower control arm bolts for tightness.
when was the last time tires were balanced?
ive seen bald unbalnaced tires casuse DW , on my jeep actually...
id put money on a bad trackbar and/or a loose mount.
i drove back from the rubicon in september from tahoe to sac with 2 loose axle side control arm bolts ready to fall off, same for the lowers, and a slightly loose frame side trackbar bolt with no DW.
so it makes me think your trackbar bushing and/or TRE are totally shot.
replace it , crank on the mount (18mm bolts) and go from there
