basalt51 said:
Every BFG AT I've seen has done great in the Snow. But what do I know. I'm from CA :dunno:
DD+rocks = MT/R
The downside of most, if not all, AT's is that they aren't optimized for lateral traction in slippery conditions (they are optimized to be smooth and quiet). Mud tires are to varying degrees designed for lateral traction (the Interco tires seem to be known for excellent lateral traction offroad) except that if you don't have sipes on the center lugs the tire needs to be digging, which doesn't happen on packed and icy snow or in the rain (there is no bite or channeling).
If you sipe just the center lugs to increase bite, and specifically design the center lugs for lateral traction and have a compound that doesn't freeze in the snow, then good MT's can begin to outperform the AT in both lateral and braking traction, and they are already far superior in pulling traction due to the large and well spaced outer lugs. I'm not suggesting that Interco Swampers are better than AT's in slick conditions...but the trxus is a different story.
I think the trxus is such an excellent snow tire (comparable in performance to dedicated snow tires for passenger cars) because the center lugs are running parallel to the forward motion of the car, maximizing lateral tread contact (the hourglass design also increases lateral tread contact). With tight center lug spacer and factory siping, the tires hold in the corners and stop very predictably. The TSL outer lugs, which are also siped, provide the forward traction.
If you look closely at the latest snow tire designs, you'll see a similar approach. The center is an arrowhead tread that runs parallel to the forward motion of the car (lots of lateral tread contact), and the lugs increase in spacing to the outside of the tire, all with heavy siping and channeling (and specialized "micro-pore" compound). The interlocking tread of the BFG AT couldn't be much different than these snow tire designs, and in my experience it does not provide predictable lateral traction in slippery conditions.
YMMV, of course.
Nay
