Will a dana 44 from an 06 unlimited fit under an xj. I know the mounting and stuff will need to changed I am just wondering if it will fit.
Thanx cardboard
Thanx cardboard
They are the same width, bolt pattern etc. Bolt in swap! At least after the previously mentioned bracketry is changed. I think even the 8.25 driveshaft will work.
yea its an 06 unlimited wrangler. One of the guys in my local club has it for sale. Its a dana 44 rear with 373 gears disc brakes and limited slip. Came out of a jeep with very few miles. He also has a lock rite he says he will throw in, along with the stock driveshaft. $450.00 seems pretty fair.
Cradboard
Cradboard
450 aint bad but you will have to get a new carrier if you want to put the lock right in, limited slip carrier won't work, might as well upgrade the gears while you are at it if you get a new carrier.
