Capt. Nemo said:
I'll direct this at Big Red also...
If you want to run 37's, run 37's! It seems there's this stigma surrounding this particular tire size. There are a ton of variables that play into breakage of axle parts, tire size being just one of those variables. If you're prepared ahead of time to fix your rig, as you should be anyway, run whatever you want. If you're looking for approval, back away from the 37's until you have the "right" axle in front.
Maybe the next tech focus should be on tires and rims with a chart that can list the different tire manufacter's actual tire size (ie. a 35" tire doesn't typically measure 35" tall...), weights, compunds (and how those compunds affect our coveted traction), etc. Maybe a seperate comparison of rims: steel, aluminum, beadlocks, etc. including weights, and material composition for strength comparisons. I'll have to set up a poll to nominate our lucky researching candidate, cause' I sure aint doin' it.
I guess my main point is that a 35 on a steel rim is not that much lighter than a 37 from the same manufacter on the right aluminum rim. If you want to run 37's, run them. Tell us your experiences. Expalin what happened if you break. Who knows, you may be just that one person whose run 37's for years and never broken anything. You'll never know until you ACTUALLY try it. If you're out for approval, you're on the board for the wrong reasons and should have never even considered 37's in the first place.
CRASH- great article.
