dumb question, but when making a setup bearing, how cruical is it to have all bearings of the same brand??? i need to fix the rear axle in my wifes jeep, and i usually use timken bearings. which is also what comes in the master install kit. but all the local parts stores have my bearings, just not in timken brand. so does that matter, or should i wait the 3 days for the timken bearings to arrive so i have matching brand setup and install bearings???
i've always used the old shim thickness as a starting point, but in my experience it's usually been close when using the same carrier. whenever i do a carrier change (specially if i'm also changing brands), it seems that they are way different. well i'll go grab those offbrand bearings tonight then and bore them out for setup bearings and use the timkens for the install.
