alex22
- CT: waterbury area
Before you say to check the diff cover, its next to impossible. It is sitting on the soft ground with no tires or durms. I can't see the rear diff cover. The drivers side door is also missing. It seems everything I know of to ID this is mising. The one thing I can see is that the axle has a hole in the stud flange to remove a retaining plate. before I buy this I want to be sure its what I need as not to waste the owners or my time.
If its any help its a 2 door with a vent window behind the D and Pass doors and says "CHEROKEE CHIEF" in big letters down the side.
yes I did search, but to no avail.
~Alex
~Alex
