Looper
- Indianapolis
DANA 44 HIGH PINION FRONT AXLE AND REAR DANA 60 FULL FLOAT. AXLES ARE FROM A 1978 FORD F250 4X4 (DRIVER SIDE DROP) WITH 4.10 GEARS. THESE ARE FULL WIDTH AXLES AND ARE A PERFECT SWAP FOR YOUR PROJECT. FRONT AXLE IS REVERSE CUT AND HAS THE DUAL PISTON BRAKE CALIBERS. THE REAR AXLE HAS HAD THE DRUMS REMOVED FOR A DISC BRAKE CONVERSION AND THE STOCK BRACKETS HAVE STARTED TO BE REMOVED SO THAT YOU CAN SET IT UP AS NEEDED. I WILL ALSO INCLUDE A BRAND NEW * SOLID AXLE INDUSTRIES* DANA 60 HEAVY DUTY DIFF COVER. SELLING DUE TO SELLING THE JEEP I WAS GOING TO PUT THESE ON. LOCAL PICK UP ONLY (INDIANAPOLIS/GREENWOOD INDIANA). $450.00 FIRM
