iroll919
- Westminster, Colorado
i am to the point where i am going to step up to 35s and am stuck in a bind
option #1 upgrade dana 30 chromoly shafts 4.10s or 4.56s 760 u-joints and some sort of extra support/truss/diff cover probably similar to what ericsxj did no locker for now
(i feel like this would be fine it seems like every wrangler around here is running 35s on their low pinion dana 30s and dana 35 rears without much trouble why does everyone doubt our xjs high pinion dana 30s and 29 spline 8.25s)
option #2 buy complete rubicon dana 44 for 1000 bucks already has 4.10 gear ratio factory air locker chromoly shafts plus stock spares and currie hd steering and aftermarket diff cover
(the problem is the d-44 is low pinion and is coming out of a tj that has been driven pretty hard)
from what i have read both axles are very similar only difference is the d-44 has 30 spline inners and a larger ring and pinion basically everything else is the same
so which route should i go? i do run several trails that have some pretty nasty rocky spots but i am always careful and easy on the throttle
sorry for the long post
