Dana 30 outer axle nut?
Spawn 93
Russellville, KY
So this should be an easy one, but what size is the outer axle nut on a 93
Dana 30??? :hang:
36mm hex
Yep... tighten to 170 (or 175 depending on your source, doesn't really matter much) ft-lbs upon reinstallation. Too loose or too tight and you will munch unit bearings pretty fast.
