Hubbazoot
- Saudi-Arvada, CO
I have been working on putting in my lift kit today and came across a lot of stuff that had been damaged on the passenger side that my dad had attempted to repair. The base of the shock mount was cracked, the top was cracked, and the LCA on that side is damaged in the mounts (I'm having to cut the bolts out in order to remove the LCA's. What is a likely cause of this damage?
The most likely culprit I can think of at the moment is jumping it and coming down hard and bad on that side... any other ideas?
