TRCM
- Newport News,VA
chevy d60 front axle, 73" wms, disassembled
- dually front axle, hubs turned down to SRW specs
- set up for 15" brakes with new pads rotors, & calipers
- 35 spl cromo inner & outer axles w/longfield ujoints
- tera-flex 35 spl lock plates/flanges
- 35 spl ARB brand new still in the box
- 5.13 gears w/all new bearings & seals
- new king pins
- MAC mini grease gun w/green grease for ujoints
- includes extra parts such as old king pins, stock tie rod assembly, extra set of bearings, extra fasteners
chevy 14b rear axle, van, 73" wms, disassembled
- shaved 14b housing w/matching HD cover
- rear disc setup, 15" rotors, calipers, & pads
- new yukon spool w/correct length ring gear bolts
- 2 sets of shafts (used)
- BTF truss kit w/pinion guard
- 1410 pinion yoke
- no spring mounts
- extra set of bearings
sell as a set only
used parts other than the housings are noted
price $ 2200 OBO
shipping on your dime, but not recommended
located in SE VA
- new king pins
- 1410 pinion yoke
- no spring mounts
sell as a set only
price $ 2200 OBO
located in SE VA
