artsifrtsi
- Northern New York
What is the procedure to replacing these? Are they replaceable, or does the whole shaft need to be swapped?
Looking at the blow-out drawing, the u-joint is replaceable, but under the Jeep last night, it looked like the joint isn't replaceable. Is it just a pressed in piece that you have to remove the caps to install into the yoke? the drawings are a bit vague...
