Been kicking around ideas from keeping the coil and shock set up to ORI struts...my xj weighs 5800lbs only has a stock 4.0 and lives in low range this could change later on with a v8 , but I may never bother with that on a crawler for Colorado...Anywho the area I want to imrprove on is body roll under big flex this is mostly a weight transfer thing when front is up on something , so I would think a rear Currie Antirock would do the job for me . The suspension is pretty behaved I have drivwn it at 60 on road and never had an issue and it has never run sway control...limits...ir bump stops , so it functions well but needs the polishing to get the most from it .
I could just wait and do all 4 corners with ORI struts , but for a slow only rig I think they may be more than I need ...but anyone with linked xj experiwnce who has run a rear sway after not running one feel free to chime in .
