my2monkeys
- Mission Viejo, CA
Those grommets are a bitch. The way I did my wife's 95 ZJ was to pry the donut shaped
piece with a flat blade driver to break it up all the way around the elbow.
Since your pulling the VC you can retrieve the pieces of hard rubber that might fall in.
That elbow has a metering orafice inside and it's most likely clogged up so cleaning it or
replacing it is needed.
I think Pep Boys or Oreillys had the grommet and elbow in the HELP section.
