cruiser54
- Prescott, Az
I'm guessing the fuel line inside the fuel tank. Am I close?
Thank you haha, I kept beating myself up thinking I had maybe gotten the timing chain one tooth off. But there was just no way, the crankshaft or camshaft would have had to move considerably for that to happen. I'm still worried about the timing chain not being lubed properly. Do you have a Comanche?
Yeah on the fuel sending unit, inside the fuel tank, the small piece of rubber hose that connects the actual fuel pump to the hard metal line. The hard bump I hit must've shaken the jeep so hard that the hose came loose. Talk about troubleshooting.
Same thing happened on my 89. I was trying to solve my stumbling when more than 1\4 throttle.
Hooked up a fuel pressure gauge that I could see when test driving. Gauge went down to 5 lbs under load.
So when I pulled the pump out I was surprised to see the rubber fuel line barely hanging on the outlet tube!
I'm the original owner so I knew no one had been "Uncle Bob'n" in the past.
Maybe at the factory the clamp wasn't quite tight and over time the pressure works it loose?
Anyway, that was 100,000mi. ago and it's still my original fuel pump.
:new: Cruiser, will your instrument panel ground help to perk up my interior? Everything in my '96 country is stock. I've got new battery cables that I'm waiting to install (all 2/0, it's over kill but it's what I had). Everything on the interior seems under powered. My dash reads just under 14 volts at start up but quickly plummets as I start turning anything on.
