So are you saying the switches themselves determine the resistance and even though the switches look identical from 97-01 there are difference between 97-98 and 99-01?????
Please confirm this is probably my problem because I don't know exactly what year switches I purchased and they are the only variable that his changed since it stopped working!!
Also does anyone know where I can find the switch resistance values to test them??
The switch modules should have small circuit boards on them. When you activate the switch, the resistance values change. Rock the switch to the other position, the value (on the same two wires) will change again. I have a '98 ZJ wheel in my '96 Country, and even with a different wiring scheme, the cruise buttons and horn work just fine. First, make sure the clockspring is good. Best thing to do would be to get a whole wheel wiring harness, 'ring' it out, and ring out yours, looking for any difference. This is, of course, assuming that the rest of the system in the car is OK. The cruise in my '92 works fine, until you turn on the headlights, then it immediately cuts out!. Just goes to show you that every car has its own annoying little traits.
