TBCherokee
- cincinnati, OH
If you have a cracked head or leaking coolant into the oil,
would your oil dip stick show excessive oil level when you check it?
I was wondering if as it looses coolant if the dip stick would show higher reading on stick as more coolant enters the oil?
I have coolant res, constantly low and can't find problem,
replaced radiator cap,
no coolant in oil or filter,
no leaks , engine bone dry on outside.
thought if it was a cracked head , small crack even if as question above, dip stick reading would rise.
thanks guys , any info helpful
