pd code 805d
- ATLANTA
is this possible? i want the 4wd out of a 1999 jeep and i wanted to know what i need to grab to make it work? is this a difficult task?
yes and YESis this possible? is this a difficult task?
EVERYTHING !and i wanted to know what i need to grab to make it work?
97 is OBD2? Why would you want to take out an existing system and installing an identical system.
If your 97 is giving you electrical issues then do some troubleshooting.
not exactly, I have covered this in detail recently (but don't have the thread link handy.) 91-97 are all exactly the same except for an electrical connector that needs to be spliced, sensors are 100% the same. 97 is unique for the electrical connector so if you don't get the tranny out of a 97 donor you have to swap or splice regardless.A 99 transmission can be put in a 97 but it is a pain to get it to work and it is more recommended that you get a transmission from a 96-97 for you 97 since those will be your closest match.
Not really I just put a 98 aw4 in my 97 only about a hour to swap over harness for the solenoids and the speed sensor and rear housing.I meant like physically it could go in but what it would take to get the electronics to work is more of a pain than to just find the right year transmission.
I want the 4wd but what is required?
does anyone live in or around gwinnett county ga? i would like for someone to come give a look at my jeeps.
I have been thinking about just keeping it and repairing the few things messed up.
