i am lifting my jeep 6inch and i havea set of rough country control arms and i was woundering how long i should adjust them. if anyone knows please help
Adjust the LCA length so you caster is as close to spec with out cranking the pinion angle down to much. Here a bookmark I have on alignments that might help you out a bit. http://go.jeep-xj.info/HowtoAlignment.htm
I do it a little different though. I set the axle at ride height with the tires off and check the caster angle at the ball joints. Have fun doing the DIY alignment!
