skylo
- Columbia,IL
What the title says. It is used, but in great shape. Great for on board air. Email me for pics. Can not figure out how to post pics here. $100
• 12-Volt
• Permanent Magnetic Motor
• Duty Cycle: 33% @ 100 PSI
• Max. Working Pressure: 150 PSI
• Amp Draw: 29 Amps
• Min. Ambient Temp: -40° F
• Max. Ambient Temp: 158° F
• Dimensions: 9.00” L x 4.00” W x 7.00” H
• Net Weight: 8.00 lbs.
The 400C is a 33% duty cycle compressor that works quickly and efficiently putting out a massive 2.54 CFM flow at zero PSI head pressure. Features include a standard ¼” stainless steel braided leader hose with inline check valve and insulated wiring for simple installation. * Must be used with a 150 PSI or lower pressure, non-adjustable pressure switch when used with an air tank.
Rates
Begin/End PSI 31" X 10.5"
0 To 30 PSI 2 Min. 28 Sec.
15 To 30 PSI 1 Min. 25 Sec.
Begin/End PSI 33" X 12.5"
0 To 30 PSI 4 Min. 00 Sec.
15 To 30 PSI 2 Min. 00 Sec.
Begin/End PSI 35" X 12.5"
0 To 30 PSI 4 Min. 50 Sec.
15 To 30 PSI 2 Min. 20 Sec.
This is some stuff off Viaircorp.com
http://pg.photos.yahoo.com/ph/stimpson13/album?.dir=/fd26re2
• 12-Volt
• Amp Draw: 29 Amps
Rates
