To OP:
Your original message does not state that you had several sensors that you swapped out and got the same reading. Please re-read your post. Is any of them OEM new or are they yard pull-outs? At least, have you confirmed any of them as “normal” when running in a different engine?
What was your pressure before the rebuild? Are you using the same sensor?
80 psi on 170K bearings seems abnormally high (very unlikely) in a 4.0L engine, regardless of your pump safety relief pressure.
Your multiple answers are tricky and lead in directions you try to dictate only. Good luck!
