Code P0340
JIMBOJAMES
Shawano WI
Can anyone give me a detailed description of this P0340 code. I know it something with no cam signal to the PCM. I have changed the crankshaft position sensor, and the cam sensor (pick-up coil) in the distributor. Can anyone give me some insight. thanks
May be stupid questions, but...
Does the engine start/run?
If so, have you reset the code?
I have a wiring diagram out of this haynes book. No I do not know how to test the wires. I cleared the codes the other day and now the check engine light is back on. So the computer is picking up a problem somewhere but I can't seem to find it.
