Clutch interlock switch jumper
Thanks for the amazing tip about this little Chrysler secret.
I found the bypass thingy (on my '98 XJ Sport Canadian model) neatly taped to the wiring below the dash just ahead of the connector for the clutch interlock switch. When I got it installed, I found that a problem I'd thought might be a bad starter was just a bad clutch interlock switch.
The service manual has a wiring diagram that shows a clutch interlock switch jumper as an alternative to the clutch interlock switch, but it doesn't say anything about what it is or where you'd find it.
By the way, there definitely wasn't any clutch interlock on my old '85 XJ (which would start in second with a burnt-out clutch) and I'm glad to be rid of it on this one.
Thanks again,
