O-Gauge Steamer
- Colorado Springs, Colorado
Given that there have been a few threads lately referencing the need to replace the clockspring. Here is the procedure to install.
Enjoy!
ADJUSTMENTS, CLOCKSPRING CENTERING:
If the rotating tape within the clockspring is not positioned properly in relation to the steering wheel and the front wheels, the clockspring may fail during use. The clockspring must be centered if it is not known to be properly positioned, or if the front wheels were moved from the straight-ahead position with the clockspring removed during any service procedure.
WARNING: THE AIRBAG SYSTEM IS A SENSITIVE, COMPLEX ELECTROMECHANICAL UNIT. BEFORE ATTEMPTING TO DIAGNOSE OR SERVICE ANY AIRBAG SYSTEM OR RELATED STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENTS YOU MUST FIRST DISCONNECT AND ISOLATE THE BATTERY NEGATIVE (GROUND) CABLE. THEN WAIT TEN MINUTES FOR THE SYSTEM CAPACITOR TO DISCHARGE BEFORE FURTHER SYSTEM SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE AIRBAG SYSTEM. FAILURE TO DO THIS COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY.
(1) Turn the steering wheel until the front wheels are in the straight-ahead position before starting the centering procedure.
(2) Disconnect and isolate the battery negative cable. If the airbag has not been deployed, wait ten minutes for the system capacitor to discharge before further service.
(3) Remove the airbag module as described in this group.
(4) If the vehicle is equipped with the optional vehicle speed control, unplug the speed control switch wire harness connector in the steering wheel.
(5) Remove the nut that secures the steering wheel to the steering column upper shaft.
(6) Remove the steering wheel with a steering wheel puller (Special Tool C-3428B).
(7) Rotate the clockspring rotor clockwise to the end of its travel. Do not apply excessive torque.
(8) From the end of the clockwise travel, rotate the rotor about two and one-half turns counterclockwise, until the rotor flats are horizontal. If the clockspring wire harness is not at the bottom, rotate another one-half turn.
(9) The front wheels should still be in the straight ahead position. Install the steering wheel being certain to fit the flats on the hub of the steering wheel onto the formations on the inside of the clockspring. Pull the wire harness from the clockspring through the lower hole in the steering wheel hub. Tighten the steering wheel nut to 61 N•m (45 ft. lbs.). Be certain not to pinch any of the wiring between the steering wheel and the nut.
(10) Install the airbag module as described in this group.
Enjoy!
