gman
- Virgin Islands
The IAC if you did not remove it may have uncoiled itself. You may want to remove it. The IAC is held in place with just 2 torx screws and a connector. When removed you can depress the plastic based spring portion into the body with one hand and wind the spindle back into the body. It's recommended positioning is measuring from the pointed top of spindle to the base of IAC, spindle should extend a little under an inch. if you have it out normally I would clean it with some Carb Spray and then shake it drain it dry, spray a little WD 40 in it shake it out let it dry a little clean it's passage in the throttle body and reinstall it.
