iwannadie
- Gilbert, Az
2004 Chevy Cavalier 2.2 auto
So, we had one of the worst rain storms I've ever seen here in AZ recently and the ole lady drove through some water... She hasn't been clear just How much but it seems like it was Deep, sigh.
The day it happened I went to pick her up after she called saying it wouldn't start. Before I got there she had thought it was the battery and was messing with the terminals. She had removed the intake hose to get to the terminals and told me a good 2 cups of water poured out of there... She said it started after she messed around with it but would idle roughly for a few seconds and die.
Flash forward to today, after having it towed home I pulled the plugs and cranked it a few times to try and get any water out. Changed the oil(no signs of water in the oil) and filter and found the air filter still soaked with water and the air box swamped too.
I dried everything that I could get to and after replacing the plugs and filter I tried to start and it just cranks but doesn't start. Before I go deeper into things is there anything in particular to look for in this case dealing with water sucked in, sensors maybe? I plan to do a compression test first and see what that tells me. Just seems odd that it went from at least starting to now just cranking and not starting. It cranks strong with no signs of distress(no vibration, back firing or anything else bad) at least, I am trying to be hopeful that its not totally shot.
