cps drivers side upper to middle bell housing.. 3 wires, has a plastic cap about 2x2 to the rear of the sensor. you can pop the cap and inspect the clearance from the sensor to the pickup ring
What I mean is that if the ignition system was removed and the crankshaft moved, the pistons will be out of order with the firing sequence. Since you have no distributor I can not be sure setting the #1 cylinder to Top Dead Center is required. I'm just throwing ideas out there.
I was realizing that the coil rail (coil pack) would require some sort of sensor that monitors were the pistons are (whether it be on the cam or crank) so it knows when to fire the spark plug. Since, as stated before, I am not familiar with the 00 ignirtion setup, I just assume that the sensor is the problem; as others have previously said, because it does explain your problem.
well I should have just kept pluggin with my original idea that it was the crank sensor. Sensor has 2 bolts that hold in in, one had come loose allowing the sensor to move ever so slightly. Would not pick up the signal.
After that was fixed there was only a few minor gremlens to chase down.
Thanks to everyone for the help!
