mountainwarrior
- Salt Lake City, Utah
Has anyone had these problems? I bought a 2000 Jeep Cherokee Sport with the 4.0 I6 on 11/10/04
Check engine light has been on 12 times cylinder #3 misfire
Check engine light was on 4 times O2 sensors
1) check engine light comes on after idling for 30-60 minutes and sometimes just comes on during normal driving
2) idles rough especially when cold
3) sometimes dies after start up
4) sometimes hard to start
11/12/2004
Replaced air filter
Cleaned battery terminals
11/28/2004
Checked gas cap
11/29/2004
Replaced spark plugs
12/10/2004
Ran complete fuel system cleaner and octane booster through tank of gas
12/30/2004
Replaced coil pack
Checked injectors replaced #3 injector and inspected injector wires
12/31/2004
Ran fuel stabilizer through tank of gas
Installed heat barrier tape on injectors, fuel rail and intake
Turned #3 injector to 2 o'clock position
1/03/2005
1/03/2005
Installed heat shield between intake an exhaust manifolds
1/04/2005
Dealer ran system diagnosis, unable to find any problems
1/05/2005
Dealer checked to make sure debris shield had been installed and checked codes, found no problem
1/19/2005
Dealer checked and found bad engine
1/20/2005-1/24/2005
Replaced engine (refurbished engine)
Exhaust Repair
1/28/05
Dealer found O2 sensor bad
2/01/05
Dealer replaced both O2 sensors
2/04/05
Dealer found O2 sensors bad again
2/04/05
Dealer relaced both O2 sensors again
Removed and cleaned out muffler
11/12/2004
Replaced air filter
11/28/2004
Checked gas cap
11/29/2004
12/10/2004
12/30/2004
Replaced coil pack
12/31/2004
1/03/2005
1/03/2005
1/04/2005
1/05/2005
1/19/2005
1/20/2005-1/24/2005
Exhaust Repair
1/28/05
2/01/05
2/04/05
2/04/05
