Lowrange2
- Abbeville, SC
Oh! There it is!!!
terryd said:I'm working for max flex w/ 3" lift. I like the flexy! here's my specs to date:
3" tera-flex coils $90 via forum
working on a new bastard pack after I wasted my 3 leaf pack. I realized that flexy<durability so new packs with poly bushings and S-10 main/add-a-leaf $70 forum
JKS adjustable trac bar $230 Kevin's offroad
K1500 front brake hoses $30 AutoZone
Ram 1500 rear brake hose $30 Advance Auto
RE 1.25 rear shackle $75 via forum
Daystar extended front bump stops $30 knowwheretojeep.com
removed rear swaybar
carry 18mm/15mm wrenches for front links
trimmed lower valence off front bumper
getting ready to measure for shocks/build rear bumpstop plates.
as of now I've got $555+ in it.... there is no cheap if you want to survive it. I've built mine over a year's time (put ZJ coils in it in Feb of last year, now I'm up to 3") getting ready to drop $70 a shock for bilstein's 5100's
89xj said:i would complete the lift with RE super flex lower control arms.
lowrange2 said:I'm pretty sure I'm gunna replace my bushings with super flex on my short arms... maybe it'll flex better than rubber all the way around.
lowrange2 said:Yeah thats how I have it figured too! lol
89xj said:i have both upper and lower RE controls arms with 4.5" lift and dont see how people get away with stock arms, not saying you have stock arms and dont want to hijack this thread, but good control arms is money well spent on any lifted xj.
Stay away from TF and also poly!terryd said:I'm looking for a matching upper/lower set. RE is top of the list, followed by TF's set. still considering building my own with the RE joints and poly bushings and haven't counted out building a long arm setup for it.... its not that hard afterall....
lowrange2 said:I have Rustys fixed short arms. Rubber at both ends. If anything I'll chop the ends off those and stick weld-in bungs and adjustable RE Joints. Hell, it might be cheaper to just buy some adjustable RE arms.
RCP Phx said:Stay away from TF and also poly!
Poly in a Ford is totally different(because of the mounting).And I dont even want to start the TF thing again(use the search feature)!terryd said:if I may ask, what's the reason? We used poly bushings in the radius arms of my friends Ford and they are doing very well. and what's wrong with TF?
RCP Phx said:And I dont even want to start the TF thing again(use the search feature)!
