banderso
- Stockbridge, MI
I'm planning to burn my RuffStuff perches onto my 8.8 this weekend, but have a quick question. My leaf springs have a 3/8" center pins with 9/16" heads. The holes in the RuffStuff perches are about 30 thousandths (haven't measured accurately) larger than the center pin heads. I haven't head of this mentioned in any of the 8.8 write-ups I've read. So I figure my options are.
1) Drill the leaves to fit a larger pin which will have a larger head. Can I just take a drill to it, or do I need to put the leaf pack in a drill press or mill?
2) Machine a spacer. I could make something on the lathe.
3) Look for 3/8" center pin/bolt with a larger head. Any idea where I would find this?
3) Call it good. Figure the fit is good enough and throw everything together. A winter or two in Michigan and the gap will fill solid with rust anyway. I'm skeptical of this, but could be convinced. How big of a gap would be acceptable here?
What would you do? What did you do if you did an 8.8 swap? What kind of fit are you supposed to have between the center pin and the perch? Thanks.
