iwannadie
- Gilbert, Az
Trying to figure this out and would appreciate any input.
2002 Chevy Cavalier LS automatic.
While stopped holding the brakes the engine stumbles and if held long enough or pressing hard enough on the brakes the engine dies. Being in different gears has no effect. I can't hear any obvious vacuum leaks anywhere other than a hissing while the brakes are held inside the car.
I pulled the vacuum hose from the booster and plugged it and the problem goes away. Replaced the check valve and it had no effect. No fluid loss that I can see.
Just trying to confirm the booster before pulling anything apart. I think by plugged the booster vacuum hose and eliminating the problem that has to narrow it down to the booster and not a leak some where else.
