jxj
NAXJA Member # 1559
- Washington
My jeep: 01 Cherokee with over 100,00miles, AW4, 6inch lift, 35 MTR.
Planning on installing the tcase skid from DPG (RA1) that does not have the cutout for the oval cat converter. My current cat has some dents/scatches and would like to replace it with a flatter converter (searched this topic - going with catco) not for performance, only to gain some clearance and fit the skid plate. I wanted to know if there is anything I need to be careful of when doing this, I want to avoid any error codes especially with O2 sensors. In the FSM it states only 4 O2 sensors-two before and two after the precats. I looked under and around the cat converter and muffler and see no additional O2 sensor in this area. Is it just a matter of cutting the old converter and welding up the new one. I've read alot of comments about adding an O2 bung after the cat but cannot see the need for it since none exist as far as I can see. thanks for any help.
