- NE Indiana
mac 'center pin took out pinion' gyvr
I might find more after I take it all apart to fix things. But so far... Lost the pinion nut, damaged the pinion seal, could have been a lot worse. pushed a tire off the rim, no real damage done. Then, broke a leaf main spring, jammed it through the floor and into a battery. Melted a hole in an ARB line with my exhaust. Smashed my tie rod pretty bad. Blew a power steering high pressure line. Threw a belt. Dead alternator. Lost a VHF antenna. Bad wheel bearings. Passenger front brake rotor and pads trashed, warn premium hub broken. Pretty sure I have a loose t-case chain, bad SYE output bearing, and I think I have a u-joint gone bad
My tires look like this /-\ instead of this |-| so I need to figure that out.....
Mine had some mad stance before the crawl. A new set of Synergy ball joints took care of that problem.
A few more dents and scratches. Bent valve stem was discovered Sunday while airing up. Hole in diff cover. Scraped the new paint on my rims but they didn't bend! That is all I believe.
Did you forget about having to weld your jeep back together on the trail?
