The trick to getting the dipstick tube to let go is to spray it with WD-40 at the joint and then gently spin the upper part of the tube inside of the pan part of the tube, just enough to work in the lube. Then give it a good pull and it will pop loose.
Clean the pan section of the tube real good before re-installing the upper half and I always clean the upper half real well and replace the "O" ring, then lube it good with vaseline before re-installing it.
