stephenspann27
- College Station, Tx
I haven't touched the CPS... if the heater on the o2 sensor is reading open.. it has to be that right? Just has to...
I had a continuous rough idle one, ran out of ideas. Ran the compression test, and found an inter cylinder head gasket leak between 2 cylinders. Rare, but does happen. Ran great at higher rpms. Only sign of head gasket leak was rough idle with this one. Oil and coolant were all fine. I doubt it is your problem. You said yours was random, which sounds like loose wires, or bad sensors like TPS with a bad idle spot on the sensor.
I had my old head off once, to replace the lifters, then I later replaced the head with a reman, during those swaps there is no changed the idle,I think I can rule out the head gasket. As far as the TPS goes.. I've even swapped on the throttle body off my parts jeep with the other parts jeep TPS still on it.. no change.. so TPS can be ruled out...
Why aren't you willing to admit the heating element being bad in the o2 is causing the bad idle (I'm trying to sleep tonight and you are keeping me from putting this problem to bed)
It's an easy test to see if the o2 heater is working without ohming wires. Put an amp probe in the heater circuit fuse socket. Checks the element, power and ground all at once.
It doesn't really sound like an O2 problem to me though. Hard to say without hearing the idle. Once again access to a scan tool to show fuel trims and other live data would put the problem to bed quick.
You do know it is an 87 Renix? He already said the heater element in the O2 sensor is open.
How about the CPS?
Plugs, wires, HV coil, HVcoil ignition circuit (under the coil), ECU?
The IAC is a bipolar stepper motor driving a plunger. You won't get any continuity from any pins to ground, you will get continuity between two of the four pins, and between the other two of the four pins, and none between either set of two pins.One more thing.. IAC is of course suspect in this situation, I've tried a J-yard one, and I now have a new one installed. When I was checking grounds, i tried to ohm out all of the contacts on the IAC plug (harness side) and all of the contacts read "open" shouldn't there be a ground among the contacts in the IAC plug?
Sounds like you've mostly got this nailed, but to clean up the remaining roughness in your idle, have you tried cleaning the throttle body (and the IAC valve seat)? Between that and replacing my distributor cap/rotor, wires, and plugs I nearly completely solved my extremely rough idle problem.
