Does anyone run Cam 2 in there Jeep? What are the pros/cons? Anything to be careful of? There is a place in Hughsville PA that sells it for $8 a gallon.
the only thing higher octane will do is let you run higher compression. ok, it might burn a c hair more effeciently, but not enough to make a difference to the 4.0.
you hit the nail right on the head. Also you may run the risk of detonation due to the higher octane. I used to run cam2 in my honda, but that was an 11:1 compression motor and even at that compression i had to delute it 3:1 with 93 octane. It would just be a big waste of money but it would smell good.assgas:
