ChuckstrPT
NAXJA Member #791
- Birmingham, Alabama
So I broke a bolt off in my front axle yoke....and broke off 2 "EZ out" type tools in the broken bolt trying to get it out....any ideas??
have you tried those drill bits use to get broken bolts out? get a real skinnny drill bit drill it into the screw then use a small extractor and screw it into the hole you just made thus everytime you screw the bolt comes out more and more
I have never actually done it myself but its always been suggested to me
What are you going to do about setting up the pinion pre-load since yours uses a crush sleeve?Have obtained new Yoke....
Now have to go get a 1 1/8th socket.................
already have a puller, and another bolt.
From what I've read...with the wheels/brakes on....just mark the nut and threads...and put it back where I found it.....:scared:
I did it when I was young and foolish, did not even torque it or mark it. I took the yolk off, installed the new one, and hung on the breaker bar to tighten the nut back up. Eventually when it breaks I will do it right, but 7 years later it is still going great.
